4wd shifting ?????
Old 08-15-2002 | 09:44 AM
jp208's Avatar
Unhappy 4wd shifting ?????
have a '00 F150 4WD, and was wondering if when shifting out of 4wd high, is there a "lag time" or waiting period for the front transfer case to "shift" out of 4wd???? I am just putting the truck in 4wd high to lube the front transfer case on an occassional basis, but it seems like when I shift out of 4wd high, it doesn't want to go back to 2wd until after I turn off the motor. Is this normal???????????????
Also, is it normal for the steering to be more difficult in 4wd high than in just 2wd???????????????
Old 08-15-2002 | 02:19 PM
S'CrewLoose's Avatar
not sure about the lag time, that could be a relay but, the steering being harder is normal....although not too much harder...make sure your not running it on hard ground in 4 wheel that will make it feel real hard to steer as you will be putting loads of stress on your front end parts.
Old 08-15-2002 | 02:30 PM
jp208's Avatar
Thanks, I was on the subdivision road and driveway, so will try it off road so to speak, don't do that much if any. Guess I should call the dealer to see for sure. Thanks again.
Quick Reply: 4wd shifting ?????
