Transmission questions...
Old 10-07-2002 | 04:13 PM
Dan97's Avatar
Coming up on time to change my transmission fluid..it's a 97' xcab, w/ 5.4L auto almost 60k miles.
When I change out the fluids, I'm also wanting to add in a shift kit. I've heard good things about the Transgo kit. Someone told me that B&M also makes a kit for the trucks (not sure tho, haven't researched it). Now my questions are 1) What is the tranny code for my truck? Or How do I find it? 2) What tranny fluid do you all recommend?
Old 10-08-2002 | 09:27 AM
TN_Triton's Avatar
I can help answer part of your question.....
To determine which tranny you have, open the driver's door and look at the sticker on the B pillar....
trans code 'U' = 4r70w
trans code 'E' = 4r100.
I used Castrol semi-synthetic Mercon V trans fluid.
Sorry, I can't help with your shift kit question. I know someone on the site will.
Old 10-08-2002 | 07:22 PM
Dan97's Avatar
just to make sure i'm looking at the right thing here...there were two stickers on my driver's side...one small w/ no real info, and the other had vin #'s and stuff...there's a small part at the bottom of the sticker...I've pointed out what I think is the tranny code...just want to make sure. Sorry, but I'm new to all this...
https://www.f150online.com/galleries...w.cfm?num=2675
Is this what I'm supposed to be looking at?
Old 10-08-2002 | 07:30 PM
Mark Kovalsky's Avatar
Yes, that's the tag, and it says that you have an E4OD transmission.
Here is a link to an article I wrote on how to change the ATF. It's written for a 4R100 in a Superduty, but the differences from that to your truck are very minor.
http://www.thedieselstop.com/faq/199...ance-AutoT.htm
Old 10-09-2002 | 02:33 AM
Factory_Tech's Avatar
Here is some info on shift kits, I wrote it, and I don't pretend to be neutral on the subject, but for what it's worth, it's agood read.
http://powersurgeperformance.net/shift.htm
G
Old 10-09-2002 | 11:50 AM
Dan97's Avatar
Ok, now I'm confused again...the first guy said that if the code was a U, then it was a 4r70w, and if an E, the 4r100. And now the 3rd reply says e40d.
Sorry for my ignorance, but as stated, I'm new to this.
So, do I have a 4r100, or e40d?
And thanks for all the help/patience.
Old 10-09-2002 | 02:52 PM
AjRagno's Avatar
Don't worry about it, Dan97.
This is how Ford lists the transmissions:
The transmission codes are:
M - Manual, 5 speed, overdrive M5OD.
U - Automatic, 4 speed, 4R70W.
E - Automatic, 4 speed, E40D.
The 4R100 is an E40D
The 4R70W is an AODE
You also have the stronger of the 2 automatics Ford offered in '97. Very lucky.
Old 10-09-2002 | 03:58 PM
The 4R100 replaced the E4OD, phasing in over a couple model years. The First 4R100 was in 1998, so yours is an E4OD.
Old 10-09-2002 | 05:41 PM
Dan97's Avatar
nods, hey, I appreciate the info and the patience.
Old 10-09-2002 | 10:38 PM
TroyK's Avatar
now if only one of these guys could explain to me why the local ford shop and ford engineering can't fix my driveline "thunk"...!!! it's beginning to **** me off...royally!
Quick Reply: Transmission questions...
