Is the gasket on my 99 F150 tranny reusable ? and looking for a pan with drain plug ?
I have a 99 F150 4x4 4.6 v8 auto is the tranny gasket reusable ? how can u tell ? also where can I get a pan with a drain plug my dealer shows none listed ?
1999 F-150 4x4,short box,step side,4.6l Triton v-8, A.R.E. hard cover,cab steps,SteelHorse bed rug (liner), Mobil 1 5w30 all the way!! more to come !
Yes the tranny gasket is reusable. They are all designed to be reused...so handle it with care.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
I believe the transmission pan says right on it "reusable gasket"
99 F-150 4x4, 5.4 Triton, 3.55 gears, Amazon Green-Harvest Gold two-tone, Lund bug sheild, window vent visors, extang tonneau cover, Custom exhaust w/flowmaster muffler (single inlet, dual outlet, 3" Chrome tips), K&N air filter, Rancho RSX shocks, Clarion in-dash CD player, Superchip flip chip
It does, I saw it changing the oil today
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
My Home Page
I saw a replacement pan at www.summitracing.com It even adds 3 additional quarts of capacity.
Drawback? COST ! It was very "pricey"...at least for me !
Looking at the www.summitracing.com site again I also found a "transmission drain kit" manufactured by B&M for about $7.00 !! A great alternative to the expensive replacement pan. It says you drill the pan next time you have it off and this deal bolts in the hole and then you have a drain plug to take out the next time. Cool huh?!?!
I put a B&M pan on last week. It's a beauty ... finned aluminum. The trans gets up to 175F-180F and that's going up hill in 85F weather.
As for the pan, it's excellent quality, brand new allen head hardware, drain plug with magnet, holds three extra quarts and of course uses the original gasket.
'00 5.4L AUTO 4X4 Lariat (Black/Silver)
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
I was pleased to discover that I didn't need a filter extension on my truck. The B&M pan has some short 2" posts at the bottom to support the underside of the filter. The instructions did mention using the 4x4 filter though. When I bought my filter from Redline, they only had a listing for one trans filter, but the one they had was identical to the original.
y2kxlt,
I changed the pan, switched to Amsoil ATF, installed a shift kit, and installed a temp gauge at the same time so I have no previous numbers for comparison.
All I can tell you is that the max temp I've seen on the gauge is 185F, and that's going up a long hill, OD off, 85F outside temp. It takes a long time for the temp to even reach its steady operating temp of 155F~160F.
