4R70W and Temp Gauge
#31
Since this was an old topic, please help my dum-dum self out!! I called Diesel Injection and the rep I spoke with was not familiar with the 4R70W. He was not sure if it had a place to put the sender without drilling a hole. I'm going to look at my transmission tonight but would like someone else's confirmation that there is indeed a plug to remove that the sender will screw right into. If I order the ISSPRO kit (9055 gauge and 8995 sender), will I be ready to go, without drilling any holes in the transmission? Thanks in advance for any help!!!
98 F150XLT, 4.6L, 2WD, Ext Cab,
- White w/ tan leather (aftermarket)
- 3.73 gears
- Gibson Swept-side exhaust
- Rack N Rail ladder rack
#33
#34
Georgekillian. Can you tell me if these senders are mechanical or electric? They sound like they are electrics. I'm gonna get one installed as my next project...
2000 F150 Lariat Supercab, Oxford White/parchment,157"WB, 5.4, 4R70W,single fact. CD premium sound, remote keyless entry, full leather, 3.55 LS,SRW, Class 3
Mobil 1 5w30 oil with Motorcraft FL-820s
K&N Filtercharger
Penda Bedliner
Solo Radar Detector
K&N Filtercharger
Penda Bedliner
Solo Radar Detector
#36
Not for nothing, when I put a temp gauge in the tranny of my Mustang(AOD, Built), the builder (Performance Automatic, Gathersburg MD)told me to install the sender in the pan, it is more important to see the temp of the fluid that the tranny was taking in, and it also provides a means of insuring the cooling system(trans) is performing it's task, also they said that you will read the fluid temp only, and in that location heat of the case will not effect it(the sender)the case will be hotter than the fluid, because the fluid is what does the cooling. And it provides a nice drain plug for service.
2001 F-150 XLT S-CAB 4.6 "Fully equipt, and Superchip'd!"
96 Taurus GL
93 Kenne-Bell Supercharged Mustang
"Injection is nice, but I perfer being blown!"
www.kenne-bell.com/owners.asp
http://www.corral.net/cgi-bin/member...p00000403&p&p0
86 Kawasaki ZG 1000 A-1 Concours
96 Taurus GL
#37
penguin149,
I installed my temp sender in the hard line going from the trans to the radiator. I want to know the max temp that the ATF reaches (195F so far).
Here's the Autometer manifold that I used, but you can make a 1/2" brass tee work just as well for 1/3 the cost.
'00 5.4L AUTO 4X4 Lariat (Black/Silver)
'95 Thunderbird SC
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
[This message has been edited by gah (edited 05-02-2001).]
'95 Thunderbird SC
