'97 f150 V6 Oil Pressure problem
My friend has a '97 4x4 with the v6... when the truck gets hot, the oil pressure drops to almost nothing at idle... then it shakes and stumbes really bad... a loud ticking comes from the top of the engine(probably rocker arms)... when he gives it the gas, the oil pressure picks back up...
was told it was a bad bearing on the crank shaft... does anyone know if this is true, or have any other suggestions...
