Help: 1998 V6 engine knock (video)
we've got a friend of a friend that brought us this truck at work. 4.2L 5spd 1998 all stock. 110,000 on the ticker.
Loud engine knock, deep inside the engine.
Here's what we've done so far:
This guy is on a very limited budget, can't pay to keep towing it places. Trying to figure out what the next step is besides tearing it all apart just to find out we need a long block
http://www.youtube.com/watch?v=jIuHsXRYGWs
Thanks guys
-Patrick
- Belt removed
- Pulled each wire off the coil pack individually no change in sound
- No SES or codes present
- sound stays with clutch applied in N or driving
Thanks guys
-Patrick
well we started to do a compression check to see how the engine performs, and well pulled out original spark plugs (original wires too) and we found some coolant in #1 cylinder, atleast i think its #1.... Its front on passenger side.
we are gonna dry everything off, reassemble, run it and if the noise is gone im gonna do a lower intake gasket on it, and if it still is noisy with everything dried out it will probably need a new engine
on
