remote oil filter
Old 02-11-2003 | 07:56 AM
smpoyser's Avatar
remote oil filter
Hey, I have a '97 with the 4.6; and I'm tired of reaching over the tire to remove the oil filter and then spilling used oil all over. Does anyone know of a remote oil filter kit? Also do later models come with a remote filter so I can look at one and see how it's installed.
Old 02-11-2003 | 08:47 AM
BigDeal's Avatar
There have been 'numerous' threads open on this topic. Here are three suggestions if you're really interested in doing a remote system for your truck.
1) Run a search of the Message Board for "Remote Oil Filter" and you should come up with enough posts to keep you busy for quite a while.
2) Do a photo gallery search for 'Galaxy'. He did a custom remote setup that is one of the sweetest installs I've seen. He's got numerous pics in his gallery of it. You can also email him from there with an questions you might have.
3) Three vendor links who offer a system for your truck are: www.summitracing.com , www.amsoil.com , and www.permacool.com .
Good luck.
My 2001 SuperCrew
Mods so far ......
---> Custom Airbox replacement
---> Magnaflow cat-back exhaust system
---> SuperChips Micro Tuner
---> Hellwig Rear Swaybar
---> Lightning Replica Wheels
---> 285/60R18 Kuhmo Ecsta STX Tires
---> NR White Gauge Face
---> Sylvania Silver Star Headlight Bulbs
---> OEM Lightning Taillights
---> Sportmasters Soft Tonneau
---> Westin Side Steps
---> Duraliner Bed Liner
Next Mods ........
---> Speed Grills
---> Custom Badges
---> OEM Lightning Headlights & Front Corners
Old 02-11-2003 | 08:23 PM
Galaxy's Avatar
Old 02-11-2003 | 08:27 PM
Galaxy's Avatar
BigDeal, thanks for the compliments. My goal has been to be known for something on here. Glad it ended up being something good
Anyways, here's the link to the post I did on my install and like he said, there's tons of pictures in my gallery...
Remote Oil Filter
Here's a teaser...
Old 02-12-2003 | 01:29 AM
BigDeal's Avatar
Galaxy..... I decided here recently that I'd take motivation from what you'd done, and build a relocation kit for myself. Went the whole way too (stainless hose, Earls fittings, TD Performance plates). Even had to fab a mounting plate for the filter base. When I was done with it, it looked terrific (excuse me for the self-compliment here). Then I fired up my truck to let it warm up, and wouldn't ya know it, the thing leaked like nobodies business at the mechanical connections between the Earls fittings. Come to find out from the local speed parts guy that the 'swivel fit' fittings I have are defective (the taper on them is not to AN spec). Said he's seen several cases of this and was glad I did a full inspection of the system before I drove off down the road. He couldn't replace them for me because he didn't stock the swivel fit fittings. Long story short here, my truck currently wears a regular filter and my 'kit' is on my workbench while I am continuing my argument with Earls Tech Support group who refuse to acknowledge any issues with the fittings, and as such are unwilling to replace them. Here's what I had in place before I had to remove it:
I take it you didn't suffer any leakage or fitting problems? I'm really annoyed since I got big $$$ invested in it (I know you can relate) and it's totally unusable right now. Have basically decided to wait until my next oil change to try to install this again. Hopefully by then Earl's will have come through for me.
My 2001 SuperCrew
Mods so far ......
Next Mods ........
---> Speed Grills
---> Custom Badges
Old 02-12-2003 | 03:14 AM
mf150's Avatar
smpoyser-
Just out of curiosity, a way you can avoid getting all that oil all over the place is to remove the filter from underneath the truck. Just curb the wheels all the way to the right, then you'll have clear access to the filter. Just put the pan underneath. Make sure you have the PARKING BREAK ON, though. I did this last night and didn't spill a drop. I have to admit, I'm thinking about a remote filter, too.
Good luck
Old 02-12-2003 | 04:04 PM
Galaxy's Avatar
BigDeal, that looks totally sweet I like your filter location too. Luckily you have a two wheel drive. I was going for a location like yours but would still had to take my skid plate off every time and that was one of the things I was trying to avoid. I love it though. Sorry about the problems. Mine worked like a champ from day one. I went with the regular Earl's fittings though. Definately the second best set-up I have seen (JK)
Old 02-13-2003 | 02:01 AM
MyFordTruck98's Avatar
Where did y'all get those "Earl" fittings and stainless hoses? Are they expensive and worth using over the neoprene hoses that come with the kits like the Perma Cool? The Perma Cool is cheap- $45 in JC Whitney. Also, if the rubber hoses were to be used, would it be a good idea to put heat sleeves on them and should the filter be mounted parallel to the original location or put anywhere? And can the motorcraft filter for the 4.2 work on it? Sorry for all the questions but I'm really curious about these systems y'all have and might put one in mine. Thanks.
https://www.f150online.com/galleries...TOKEN=37026799
Old 02-13-2003 | 02:15 AM
BigDeal's Avatar
Originally posted by MyFordTruck98
Where did y'all get those "Earl" fittings? Are they expensive and worth using over the neoprene hoses that come with the kits like the Perma Cool? The Perma Cool is cheap- $45 in JC Whitney. Also, if the rubber hoses were to be used, would it be a good idea to put heat sleeves on them and should the filter be mounted parallel to the original location or put anywhere? And can the motorcraft filter for the 4.2 work on it? Sorry for all the questions but I'm really curious about these systems y'all have and might put one in mine.
Where to get the fittings? I got mine at Summit Racing, and yes they are expensive. I looked at the Perma Cool kit too. My take, if you're going to run hoses under your truck to carry the stuff that prevents your truck from going 'boom', I'm going to make sure I use the toughest hose I can get. The Earls fittings are also a big step up from hose clamps (why all the NHRA Top Fuel guys run them). When you run your remote kit, you'll probably have the opportunity to step up to a larger filter (I did). I think Galaxy runs the same Mobil 1 (M1-301) filter that I will run when I resolve the problem I currently have with my fittings. Take a look at the pic I posted in my earlier post. You may be able to mount your remote filter on the frame rail under the radiator shroud like I did. Good luck.
Old 02-13-2003 | 06:35 AM
msparks's Avatar
You can also utilize high quality hydraulic fittings. Most hydraulic shops carry everything you need!!
Same goes for the hose!
Old 02-13-2003 | 02:58 PM
What's y'all's opinion of this kit I found on truckperformance? It's made by Milodon and is $ 82.95? It seems to be a step up from the Perma Cool kit. Just curious because I can't afford those special racing fittings.
http://www.truckperformance.com/disp..._21570_500.jpg
Oh yeh, over time, wouldn't stuff build up in any of the hoses? Wouldn't they need to be cleaned or replaced every so often?
Old 02-13-2003 | 03:44 PM
JMC's Avatar
JMC
Looks like an OK kit. As long as the fittings do not leak you should be fine. You could always add the SS braid later.
JMC
Old 02-13-2003 | 08:20 PM
Galaxy's Avatar
MyFordTruck98, Just so you're clear on something (sorry if I misunderstood) the braided hose that BigDeal and I have is NOT a braided covering for any rubber hose. It is real stainless braiding that is manufactured/embedded into the hose itself. Very good, strong stuff. And expensive. -10 runs around $8 a foot.
Your filter is going to be dependant upon what the manufacturer of the remote kit says with almost 99.5% of them requiring a FL-1A (or Fram PH8A--- [can't believe I just said the "F" word]) style filter. My recommendation, and probably everyone elses, would be to mount the filter verticle so you don't have to worry about oil draining out of it when the truck is off. Most good filters have a check valve to prevent this but why push it.
Old 02-13-2003 | 10:47 PM
Thanks guys.
Oh, Galaxy, I didn't mean to sound stupid earlier, what I meant by "over" is : Are the ss lines worth using "in preference to" the rubber hoses. I'm sure the rubber ones are ok, they are used on every kit I've seen, and like was said before, I can always upgrade later.
By the way, (Galaxy and BigDeal) great job on those setups! They look cool as hell!
Quick Reply: remote oil filter
