Please Help!
A year and model might help troubleshoot your problem.
I would try replacing the fuel filter with a different brand. Or maybe draining the tank to see what was in it.
However fuel flows to other cylinders you probably have one of several problems dependent upon what engine/ PCM configuration is on your vehicle.
Just because you have spark when you ground the plug doesn't mean that it is the right spark!
Instead of swapping injectors with another cylinder try swapping a coil and see if you can move the miss.
Also check the connection to the coil and while you are in there you might as well replace the plug.
I seriously doubt the miss was caused by the fuel filter replacement, just a coincidence.
