4.6 engines
The windsor has better interchangability with the biger Tritons. 8 bolt flange on crankshaft, same as 5.4 and 6.8. Uses individual cam bearing caps. Full floating piston pins. But that is only usefull if you plan on swapping parts with a 5.4. If you wanted to use lower compression pistions because of a supercharger you conld not use Lightning pistons if you had a Romeo engine. You could if you had a Windsor.
JMC
JMC
