port and polish throttle body?
HI!... You will need the following to do the job right and somewhat easy :
- One 3" 60 GRIT paddle sanding wheel.
- One 3" 80 GRIT paddle sanding wheel.
- One 3" 180 GRIT paddle sanding whee.l
- One 3" 240 GRIT paddle sanding wheel.
- One 3" cotton polishing wheel.
- Aluminum polishing compound.
- One *STRONG* high speed electric drill. (DO NOT USE A DREMEL)
- One carbide cutter. (cylinderal with rounded tip)
thank you so much neal i was waiting for ever for someone to tell me how to do it, all it does is clean it up and flow air better right? all i doo is clean it up with the ruffer grit than polish it away right? i leave the butterfly alone right? sorry for being such a nag, if you ever need to know about suspension systems i am your man thanks again
https://www.f150online.com/galleries...w.cfm?num=6550
here are some pics i took the other day as i was washing it i dont know how to get it to show just the picture i am going to make more albums with all the mods and better shots
semper fi
semper fi
well i atempted to do it this weekend but i treid to do it with my battery operated drill, i almost got done with the throttle body beffore my batt went dead i am going to by a plug in drill and finish off the throttle body and elbow this weekend and i will post the results and if i could feel a diffrence witch i doubt since it will only be a hp or two from the better airflow, i also found my old bolts for the throttle body so i can take off the stupid throttle body spacer, if anyone wants a brand new throttle body spacer with all the hardware for a 5.4 it is a poweraid i will give it to the for a cartoon of smokes or a case of beer
