engine stall
Engine stall - TSB 17646
I just had an identical problem with my 04 S'screw. Returned it to the dealer, they found a technical service bulleting describing the problem. TSB 17646. I believe they wound up re-flashing the control module, but it's hard to tell from the gibberish on the service sheet and I haven't been able to find a description of the TSB online. This appears to be pretty widespread, found lots of similar reports of engine stalls on 04 F-150's. I'm betting this turns into a re-call.
Long & short, get it back to your dealer, ask them to reference the TSB above. Best of luck.
