P401 with Shorty Headers
I just installed a New Factory (AER mfg, Romeo Plant) 4.6 in my 1997 F150 after getting a head leak at 180K, as options I installed Shorty Headers (Pacesetter, I know, I know,,,cheap), and a BBK 75mm throttle, went ahead and replaced everything including ignition, DPTE Sensor, EGR Tube, Cleaned throttle adaptor (1 EGR port clogged with Carbon). After 400 Miles I have gotton TWO P401 codes. The EGR valve only has about 30K on it. I checked my hoses.
#1 - Coming off highway from 75 mph down to 20 mph (1/2 Tank gas)
#2 - Put pop-up camper in bed, and ran about 12 miles and code lit along with drive train error (blinking overdrive light)
I am not worried about the drive train error, I can fix that, probable need a new tranny anyway (shuddering, even after two torque converter flushes), But am perplexed by the P401 error,
IS IT THE HEADERS and the LOWER BACK PRESSURE ?
If so, how do I fix it ?
I dont know what kind of mileage you have on your truck but ....... sometimes clogged EGR passageways in the throttle body elbow can cause this. Sometimes a more restrictive exhaust will divert a sufficient amount of gases through the elbow even though there prtially clogged up. But going to a more free flowing exhaust will allow enough of the exhaust gases to bypass the clogged EGR passageways to throw a code.
It's a long shot but maybe those EGR passageways need cleaning? If so, clean the EGR valve and throttle body elbow then reset the computer and wait to see if a code is trown again.
Good luck.
Good luck.
Good Info Guys, in response
HOSE FITS
1. Checked Hoses, The new DPFE sensor has a large and a Small Port, The hoses match and they match the EGR tube. One suspect issue is maybe a crack in the hose, I did not replace hoses and the ends are a little brittle.
2. One Item - When I installed the EGR tube, (new) the fit to the shorty headers was a bear to get in, I may have the flange ****ed at an angle at the headers - maybe I have a leak ? Thoughts on this.
3. Just took the truck for a 1000 mile turkey hunt, and the code appeared four times, three times directly after a full tank and getting on the highway in the first 10 miles.
ELBOW CLOG
1. When I installed the new engine - one port was clogged but I cleared it and cleaned the part very well.
HOSE FITS
ELBOW CLOG
