5.4 Towing ability
5.4 Towing ability
Would the 5.4 in an F-150 4X4 be strong enough to pull a medium sized (2 horse) goose neck trailer?
I'm concerned about the bed being too tall for goose neck trailers and also whether the 5.4 would have enough "***".
Originally Posted by Ponyrider
Should have mentioned I'm looking at '97 / '98 models...
Ford put more-powerful PI heads on trucks beginning in late 98, I believe, so they have a bit more power.
All 99+ trucks will have the PI heads.
My 97 was factory-rated at 235hp.
The same engine with PI heads is rated at 260hp.
That being said, we towed a 7,000-lb boat/trailer thru the desert for years with no problems. She pulls the boat a bit better these days
Thanks for the help, guys. My main concern was the bed height, but I bet it will be OK. I'll just try and find a trailer with an adjustable goose neck.
I bet the tranny will take a beating though, as I want an auto so my wife can use it.
I'll hook up a tranny cooler of some type. any good products out there?
I saw an "old" body style ('97-'03) F150 pulling a small gooseneck the other day. I have to admit that was the first time I had seen an F150 pulling a gooseneck/5th wheel. It was sagging a little bit, so it might not be a bad idea to install some helper springs in the rear (these are relatively cheap and easy to install).
Like the others said, I would *try* for a '99 up, but any of the 5.4s should be able to do it.
click here
As everyone else said, try to go with a 99 or newer. I would try to get the E4OD trans and not the 4R70W. The E4OD has been proven and I know the 4R70W is a good transmission, but I would still look for the E4OD. Installing a set of helper springs is definately a good idea, and like Johngs said, there pretty easy to install. You could always have Mike Troyer tune the truck for you and you'll get even more out of it. Hope this helps.
Hello Ponyrider,
Can't have mine ... but with a few mods my 97 does fine. https://www.f150online.com/galleries....cfm?gnum=5415
Originally Posted by fasterhorses
Hello Ponyrider,
