trouble codes
By the looks of it, you have a damaged / corrupted PCM with a "P0602" & "P0605". I wouldn't trust any of the other codes produced by the PCM until the PCM gets reprogrammed.
P0602 - Control Module Programming Error
This Diagnostic Trouble Code (DTC) indicates programming error within Vehicle ID block (VID).
VID data corrupted by the scan tool during VID reprogramming.
P0605 - PCM Read Only Memory (ROM) error
The PCM ROM has been corrupted.
An attempt was made to change the calibration
Module programming error
Physically damaged PCM
Good Luck and let us know the results!
Originally Posted by lees99f150
P1211 Injector Control Pressure Sensor Above / Below Desired
P1690 Wastegate Solenoid Circuit Malfunction
With the definition of those codes, I'd be inclined to think it's something with the tuner like Steve said. Kinda hard to have an ICP or wastegate solenoid fault when you ain't got neither on your engine.
