Sluggish!!??
Sluggish!!??
OK! So i realize that 98,000 is alot of miles. My 98 f-150 has never had a code come up nor had any engine problems. All maintenance is current. I am still having a problem with the truck not having the power it used to. Are my injectors bad? and if so would a code come up? Do I have a bad o2 sensor going bad? Any ideas gentlemen? The truck runs great and idols perfect. My gas milage is down a bit and my towing is off a bit. Torque converter maybe??
Help me out here. Mods include: Dual exhaust, K&N FIPK
Running Seafoam though will help your truck run better, but it won't clean out the EGR ports if they are totally clogged with carbon. You can't see if the ports are clogged without taking the entire TB off either. I did mine a few weeks ago, one port was 100% clogged the other 30%. I ran seafoam through two times prior to doing this. Although my mileage still sucks, I did notice a difference in performance afterwards. Set aside a good couple hours because it is a job, do a search on cleaning EGR ports and follow the instructions.
Sounds like it's time to start doing all that maint. these trucks call for, I have a 97 with 120000 miles and have been playing catch up from the previous owners lack of tune ups. Some things I've done, clean the EGR ports (totaly plugged) clean the MAF, new fuel filter (couldn't blow air through it) new plugs/wires (had a code) K-N, Sea Foam (and a few others that aren't relevant to this thread) O2 sensors are next.
All of these fixes can be done by a person of average mechanical ability, especialy if you search this site for the correct way to do them, I have and it's saved me hundreds if not thousands of $
