351 C...
Old 01-24-2006 | 07:23 PM
cyclone vampire's Avatar
351 C...
I'mm looking for a older ford F-150 to use as a work truck, But any how heres a question.
81 F-150...truck is in nice shape, runs good, seller claims engine is a 351C, thier is no engine ID (sticker on valve cover) valve covers and block are painted Ford Blue, But I doubt 351 C were made by Ford in 81, or engine could be a transplant....To me it looks like a 351w with Blue 351C valve covers, I don't have the vin and I don't no were to look on the block For a engine ID number...
Thanks....
Old 01-24-2006 | 07:46 PM
hammes5's Avatar
It probably is a windsor or it could have been originaly a 300 I-6, that was replaced with a 351c. they both use the same bellhousing bolt pattern. I did one of these conversions years ago and it worked out well. Take a closer look at that block. You may have a hot rod in your hands.
Old 01-24-2006 | 07:54 PM
Were do I look on the block? I was 6 years old in in 1973, so I have no practical expierance to go by, just reputation..also it has a 2bbl carb which is not abnormal, would the firring order be stamped on the manifold and would it be diff. than a winsor engine?
Old 01-24-2006 | 09:37 PM
DarnEFNET's Avatar
Could be a 351M, they look like Clevelands but were phased out by 1982. A Cleveland never came in a F series pickup stock.
Old 01-24-2006 | 09:43 PM
351 W 351M and 351C....I know thier are 3 351 engines, all diff. from each othier...3 diff. spark plugs.....but once again, how can you tell 351 engine, buy looking at the engine?
Old 01-24-2006 | 10:07 PM
did some serching...351C should have eight bolt's on the valve cover, windsor engines have six....possibly this coud be a 400M
Old 01-25-2006 | 12:05 AM
Bluegrass's Avatar
Big differences between the Windsor and Clev engines.
Valve covers are wider on the Clev, the front water pump areas is way different. The water pump mounting is a part of a block extension casting.
The C engine went out of production by about 1974 being replaced by the M series engines in 351 and 400 cu/inches.
Old 01-25-2006 | 12:20 AM
Chevy ???? I don't care abought no stinking 350... Spark plugs are under the Chev V/8 ex mainfolds, and later vave cover gaskets, 1980 and up are not the same, I'm well versed in chevy's I'm try ing to figure out how to tell a 351 Cleavland engine By looking at it...I have owned a 429(no cJ ) 351W and a 400M and lot's of 302's, some info on the nent I foud say's the Cleavland engie has eight bolts on the value cover.
Old 01-25-2006 | 12:27 AM
Bluegrass's Avatar
If you owned 351w and 400m then you already saw the differences.
Old 01-25-2006 | 12:40 AM
I'm old and the spoils of my youth are taking thier toll.
Old 01-25-2006 | 12:58 AM
Kool Aid's Avatar
Maybe this will help..........
www.fordmuscle.com
Old 01-25-2006 | 12:59 AM
I so thank you Kool Aid....Cheers...
Old 01-25-2006 | 01:02 AM
you have to pay !!!! oh well...
Old 01-25-2006 | 01:13 AM
Kool Aid's Avatar
Sorry, didn't realize that you had to pay. :o
Old 01-25-2006 | 01:27 AM
Talking
it's ok....I found more info...on the 351 C the upper rad hose dose not go into thermosat housing on the intake mianifold. thier is no thermosat housing on the intake... the pic posted is a 351C
Quick Reply: 351 C...
