Power Steering Pump
try this
1.start the vehicle and let it idle
2.fill the reservoir to the full mark,leave the cap off of the pump
3.from outside the vehicle turn off the engine and, with a flashlight,look inside of the reservoir.
You are looking for the fluid level to fluctuate or even spill out of the reservoir.Also look for a cloudy fluid.This usually takes about 15 seconds after you turn the engine off and it almost looks like the fluid is carbonated.
If any of these things happen you have air in the system.95% of all power steering noise is caused by air.One of the easiest ways to purge air is to
1.start the vehicle and turn the steering wheel to the full left posision.
2."Bounce" the steering wheel off of the steering stop a few times
3.emediately after turn off the engine and let the vehicle sit for 15min(Never turn the steering wheel with the engine off because all you are doing is pumping more air into the system)
4.start the vehicle and do the same process again but on the full right posision.
5.alternate between the 2 directions several times .
There is a very good chance this will purge the air.It works on 95% of the cars I work on.
One more thing to consider.If the noise is there even when you dont turn the steering wheel,It could be a bearing on one of your pulleys.This sounds very similar to power steering noise.Use a stethescope or a long screwdriver to pin point this.A screw driver works almost as good as a stethescope if you put your ear to the end of the handle and put the blade near the mounting location of the pulley in question.
I hope this helps and it probably wont take you half as long to figure out the noise as it did to type this.I suck at typing.
Well, a friend and I jacked the front end of the pickup off the ground, leaving both wheels free to turn. It didn't bind at all. So I took it to a tire store to see if they could see anything, and they said pretty much all my ball joints are bad and need to be replaced. Do you think this is something that could cause the binding when turning? The tires are fighting against each other?
