2001 F-150 Triton V8 jerking/hesitating between 30-50mph
Old 11-19-2006 | 05:52 PM
stars2man@yahoo's Avatar
Question 2001 F-150 Triton V8 jerking/hesitating between 30-50mph
I have a 2001 F-150 Triton V8 4.6L Lariat that suddenly has started jerking/hesitating between 30-50mph. The first time it happened the Overdrive light came on. The next day the light was off and so was the jerking. The Mechanic told me to put some high-test gas in it. Now the Service Engine light is on and it's jerking alot. What's wrong with this?
Old 11-19-2006 | 08:38 PM
projectSHO89's Avatar
You need to read your codes.
Old 11-19-2006 | 10:48 PM
00Ford4X4's Avatar
I had a very similiar problem with my 2000 F150 5.4. Took it to the dealer and it ended up being two bad coils. I also has a very strong fuel smell from the exhaust due to the fuel in two cylinders not being ignited. Just my two cents.
Old 11-20-2006 | 12:11 AM
poolvibe's Avatar
If the overdrive light blinked it stored a code in the computer. Any mechanic can pull it and point you in the right direction.
Old 11-20-2006 | 01:24 AM
jbrew's Avatar
Hi,
Great advice , get those codes read stars, most likely a coil , 2001 4.6 so you have the COP system correct? You are wireless - lol. - plug wires , you are without , is that right ? High-test lol, haven't heard it called that Ina while. That Mechanic wanted to see you buck a little higher I thinks. haha.
The TPS is a possibility as well , but TPS malfunctions , usually do not attach to one certain area within the drive cycle as you described. The problem exists between 30- 50mph - Common Coil failure scenario .
Go to auto zone for a free reading , doesn't matter what the auto zone employee says , just make sure that you yourself see the numbers on the code reader , report them back to this thread. There usually someone around to help you with it.
If misfiring , unplug that cylinders injector (saves gas , protects your cats and you won' t catch on fire .) kiddinggg, sheeesh.
Good luck.
Old 11-20-2006 | 02:39 AM
tritonpwr's Avatar
4.6's have been COP from 2000 and up.
Old 11-20-2006 | 06:28 PM
jbrew's Avatar
Shhhh!! , you wern't suppose to answere, Ieyiyi
Quick Reply: 2001 F-150 Triton V8 jerking/hesitating between 30-50mph
