water sound in dash
Geez my truck has made that sound for years - coolents never low, a fast dripping sound , maybe a water running type sound at times. I only here it after the truck has been turned off. Figure it's an air pocket that water backflows into after I shut the vehicle off- in the heater core. hasn't hurt nothing.
Running water sound when you start - perhaps low coolant level and you're hearing air/water moving through the heater core. Running water sound when you shut it off, very likely a pressure equalization in the A/C system (or cooling system).
A good test for leaking heater core is to get the engine warm and turn on your defroster. If the windows fog up, it's toast. Another thing to look for is coolant dripping down out of the drain for the A/C or on the passenger side carpet.
Originally Posted by F151
My '00 does that too. Seems like it always did. Sure hope the over heating didn't cause any damage.
Mine never once came close to overheating - big dual core radiator with two seperate coolers in front of that for trans and oil came that way from the factory - never a prob. It just made that dripping sound when you shut it off - seems like it always has..I have new core lines on the bench that I need to install - mine are getting bad and leak once in awhile. I flush it every year , the block as well ..No probs and I have 200,000 miles on my 5.4L.
Same issue
Mine started after I changed heater core but I don't know what to do to fix it. Do I need to flush the full system, if so how to empty all lines?
