Blown Engine With Pics!!!
Originally Posted by charic09
I have the pistons out now and the break isn't consistent with a lean condition. If I was running lean enough to take out a piston there would be melted marks around the break or the edges of the break would be well rounded, instead they are just slightly rounded and the area where the piston broke is carbed up like the rest of the piston, suggesting to me that the pistons were like that for a while. Also, a piece that size would HAVE to leave some kind of mark either on the piston, cylinder wall, valves....somewhere. The cylinder walls are spotless. One merchanic suggested that the piston may have been dropped and broken, and someone installed the piston anyway to cover up their !@#$up. Wouldn't the engine be running hot if running lean enough to do that to a piston? My temp needle was barley at a quarter.
From your own evidence.....
1. Changed the exhaust system with no mention of tuning to compensate for that.
2. Ticking/knocking sound from the upper engine under load.
3. Lean code cleared but not investigated
4. Chunk missing off the piston.
I'm with JMC and will say that these are all classic signs of detonation. The missing chunk could have been blown out of the exhaust. Stranger things have happened.
Combustion chamber temps when they spike have little effect on coolant temps. It's all over too quick.
Yeah I see what you mean. So how should I begin to tune my engine to compensate for my exhaust system? I am going to install the 02 simulators (which I am assuming goes into the secondary 02 sensors where my cats used to be). I have a duel 2.5 inch with a 70 series magnaflow duel in duel out muffler. What steps should I take to diagnose what is causing detonation. I do think the timing chain was off a little so I will fix that problem during reassembly.
I don't buy it. That missing chunk is old. look at the soot deposits on the break. Something is going on, but it isn't detonation. I think something mechanical is broken. (besides the piston) This is very unusual. I wonder what it looked like when they put it together...
Thats what a few of mechanics told me. The material is cast aluminium so it would be a light grey in color. Hey get this too, one entire bank (undamaged side) had the wrong plugs in it. I think they were just a different heat rating but yeah they were all wrong. The damaged side had 2 of the right plugs and 2 more wrong ones. I suggested that the shop told their apprentices to have at er when this engine was ready to put in and, like I said, maybe someone dropped the darnded thing and they used the broken one anyway to cover up what they did. Who knows. Again, even with the ticking, right before I had a misfire the truck ran good. Idled good ran smooth hardly could hear the engine from inside the cabin on idle, started in cold weather great. I figure if I did a compression check I would of goten full or near full compression. So again all these facts leave me very confused as I am thinking it is leaving you guys too.
hey now i wouldnt go that far, wait til you pop the caps to the cam journals and look at their condition before you get too excited. lol
im sure everyones still saying detonation issue and that may be correct still. im not seeing anything to justify otherwise, but the buildup on the fractured edge is kinda odd, meaning it has some time on it that way... no scoring of the cylinder wall?
