V10 Swap
#33
Hmmmm......
To fund this i should write a manual . Getting those tbars ordered today. Got a bit of the small fab work done, trans cooler lines and mounts, power steering lines, got the y pipe done and fix the ford stupidity. The stock y pipe actually drops to about 1.5" for 2" on both down pipes. That seem a little crazy so i little plasma cutting and a LOT of mig wire and gas and presto y-pipe with no less then 2.25 diam collecting into the stock 3" pipe to a 3" cat.
Josh
Josh
#34
#35
Originally Posted by camdenlake
I get that question alot. What about the fuel economy. Dont really care. I dont expect it to be too nasty but whatever. As long as i can shred tires as will i am all good.
Josh
Josh
Either way, sounds fun.
#36
Progress Report
Well the project is moving along fianlly. Got the Tbars out of the aarms and finally got the new tbars. They are the correct ones spring code 7 did the trick. I got 7700 springs for the rear from a boneyard as they are disco'd by everyone else. Got the tcase attached last night. That is a big step as now i can finalize the motor mounts and drive shafts and many other items. I have ordered my drive shafts from a local shop. They are to be done for friday. If nothing else goes horrilby wrong might be able to start it this weekend .
Thanks for following along.
Josh
Josh
#39
#41
lunch break :)
Took some pics before lunch break. Lots done you cant see but the engine is more or less back togther. New plugs and granatelli colis are in. A few other things aswell.
http://camdenlake.ca/PhotoAlbums/album_1183291875/
#42
It Lives :):):):)
Well she starts and makes lots of noise. No exhast just manifolds. Couldnt wait . I only let it run for about 5 secs as i didnt want the flames to melt anything. It responded to thortle input so thats good. Just got to put drive shafts and exhaust on and tidy up some wiring. I think thats it...... Dont care it ran . Should have a full test later tonight or tomorrow am.
Josh
Josh
