Mixing fuel system cleaners
Last time I filled up my truck I put a bottle (well 80%) of seafoam in it to hopefully clean out the injectors etc...I just found a bottle of Amsoil on my shelf that I thought I had. I have 3/4 tank left of the Seafoam tank and I was hoping to change my fuel filter after I finish this tank off. Would it hurt to put a couple ounces of Amsoil in with the Seafoam or should I just wait?
Originally Posted by Norm
If you say so, we all know what an expert you are.
I wouldn't mix them. Save the PI for after your filter change.
i just changed my fuel pump out this weekend. at im at 154K miles. my tank is spotless not a grain of sand or corrosion inside it looked brand new. i was like wow! the only additive i ever used at acetone or B12. the fuel system cleaners caused alot of deposites in the combustion chamber because they dont burn as well. which is how they clean out the fuel system they gunk up and collect small particles and pass them through the tail pipe. so it actually harms performance
Originally Posted by Faster150
I just changed my fuel pump out this weekend. I'm at 154K miles. My tank is spotless, not a grain of sand or corrosion inside. It looked brand new. I was like wow! The only additives I ever used were acetone or B12. The fuel system cleaners cause a lot of deposits in the combustion chamber because they don't burn as well. This is how they clean out the fuel system: they gunk up and collect small particles and pass them through the tail pipe. It actually harms performance
I think I fixed it. Is that what you were trying to say?
Acetone is a solvent which is why your tank is "spotless". Gasoline is a solvent as well. Your filter collects the sand or particulate material.
Most fuel system cleaners are solvent blends as well. If they "gunked up" as you say they wouldn't be cleaners now would they?
Some fuel system cleaners work very well, some don't. Ford themselves recommend Chevron Techron products.
Originally Posted by chris1450
Ford does not recomend any additives, at least in my manual. The techron they are talking about is in the gasoline you put in the tank from chevron stations I do believe
