new coils
Originally Posted by Bryguy1822
similar issue going on here...p0304..cyl 4 misfire. ordered coils, received them. bought manual to figure out how to change them. no luck..anyone have a step by step guide on how to change the cyl 4 coil? i've got an 01 Ford F150 scab 4x4 with the 5.4L V8 Triton engine. also need to know what tools to have on hand. extendors, sockets sizes, etc... friend mentioned i might need to remove the fuel rail.. i don't like mess'n with fuel.
Originally Posted by MmmBuckles
its cool. for yours, you have to take the coils off the plug boot. they are held on by a 7 or 8 mm bolt. once you get those off, you should be able to pull the wire off the plug. then you will need a plug socket to remove the plug
no problem. i hope you figure it out
Bryguy - you don't have to disconnect the supply and return lines on the fuel rail - just take the four 8mm bolts out of the rail and flip the rail up ontop of the manifold.
Just incase you didn't realize this yet
