First Oil Change
Old 07-16-2007 | 09:47 AM
CowboyHokie's Avatar
First Oil Change
Hit 5K miles and decided against the free oil change at the dealer. I wanted to do all of them myself and the convenience factor of going to the dealer definitely came into play.. After reading the posts here about the Ford Gorilla filter tightner, I shopped around for some help. First I bought a jaw grip style wrench along with 2 5qt jugs of Mobil-1 5W20 synthetic and a Motorcraft FL820S filter at WM. Later in the week, I was in Advance Auto and picked up a big Blitz aluminum pan to catch drippings and saw a filter remover with a slot for a ratchet. I picked the one that fits the 820 filter.
So yesterday morning with the engine all cool, I started the assault. I wanted to start with the filter instead of the drain plug, because if I couldn’t get it off I could punt and take to the dealer. First thing I noticed was the angle of the filter is truly awkward to deal with. From the bottom, I could not even attempt it. My skid plate blocked access. From the top, I quickly determined I needed to remove the air intake baffle. One small screw is all there is to remove and then just push it out of the way. As I looked down at the filter I noticed that the factory filter was not a Motorcraft – at least it didn’t have markings and the outer grooves were spaced differently than the 820 in my hand. So the ratchet style remover would not work. Getting the jaw grip remover in place was a challenge but doable. I got a good hold on it and twisted. The filter started crushing on one side, but I felt the filter loosen a little and I knew it would be possible. I did need to get a 3 ft piece of pipe to save my arms from getting scraped up and to make it easier to apply push down leverage to the jaw grip wrench. It really helped. I placed shop rags under the filter (helpful hint gleaned from another post) to catch filter spillage and started draining from the pan. My factory filter was white and only had an icon on the outside about not placing in trash. Inside it had a ZZ stamp. After draining, I put the new filter on and loaded it up with 7 quarts of Mobil-1. Driveway was clean and just a few drops on the Blitz pan. I did have a small puddle on a black shield under the filter where my rags were not put in the best location, but it was easily wiped away…..
Only a few arm scrapes, and the next time will be a piece of cake.
2007 F150 SuperCrew Lariat 4X4
V8-330 5.4L SOHC
Old 07-16-2007 | 11:12 AM
doctorD's Avatar
Did you go with the basic Mobil 1 or the Extended Performance?
From reading this forum, it is my understanding that the original filter is a booger to remove. Sounds like it in your case as well. I've also read that it is indeed a MC filter, just unmarked.
Old 07-16-2007 | 12:04 PM
Originally Posted by doctorD
Did you go with the basic Mobil 1 or the Extended Performance? basic
From reading this forum, it is my understanding that the original filter is a booger to remove. Sounds like it in your case as well. Yep, but if you take your time and don't abuse your hands and arms it wasn't that bad. I've also read that it is indeed a MC filter, just unmarked. If it was a MC the outer casing was shaped differently. The grooves were spaced farther apart than my new filter.
Old 07-16-2007 | 12:08 PM
MC filters are made by more than one OEM.
You may want to consider installing a remote filter mount at your next oil change to make your job easier.
Old 07-16-2007 | 12:49 PM
ncranchero's Avatar
As of a year ago Motorcraft filters were being made by Lubefiner. That may not be the case today .......
Old 07-16-2007 | 01:07 PM
Its better change the oil with the oil/engine hot b.c when its hot, it holds the dirt and junk in the oil better, so more of it comes out of the engine
Quick Reply: First Oil Change
