Patman03sprcrw Towing help/recomendations
Patman, get a good hitch like Draw-tite or Reese or.... but a good class 3 at least. I just got a class 4 Draw-tite for around 200 bucks canadian. Are you pulling a car trailer or dolly? In any case, get a frame hitch. If it's a trailer, figure about 14-16 inches to the bottom of the trailer coupler and see how many inches to the top of the inside of the reciever on you're truck. Looks like a ball mount with about 4 inches drop turned upside down is what you'll need. Other than that, you'll be fine. I just towed my car home, a 4k lbs car on about a 2k lbs trailer, at least, no problem. I had a weight distribution hitch that was too high (borrowed with trailer) so it squatted my truck a bit too much. Still, it pulled absolutely great, all the best man, and beware, when u-haul ask what you're pulling, say a miata or something small. Do a bit of a search on this and you'll see.
I think 99+ do, but yah mines got 4 pin harness on it. Just called one of my other buddies that said hes got one that will work, but it needs the bolts.
Would I need grade 8 bolts?
Well, I thought I had something interesting to say, but then I re-read your original post and realized you clearly stated you had only the ball on your bumper for a hitch... Sorry for the wasted space.
For what it's worth, I think buying a frame mounted hitch would be a worth while investment.
Mike
Mike
Originally Posted by BLUE20004X4
Patman, beware, when u-haul ask what you're pulling, say a miata or something small. Do a bit of a search on this and you'll see.
I think i might end up borrowing the one that Fasterf150 has at his parents house. If i cant get a hold of the guy that lives in my complex with a CIII hitch already on his truck.
and Zaair i know what you're talking about, the top of the bolt has a large square head on it that hits the side of the frame, or they have the ones like that are on the shackles, with a bracket that comes over the side of the hitch that wont rotate...
-Patrick
LBS?
Im still trying to get a hold of a C3 hitch, if not we will be getting a car dolly and pulling the driveshaft out. I think i would prefer to have a full trailer tho, would definetly be safer since the dolly wouldnt have its own brakes.
The reason I say use a dolly is you said you’ve pulled a trailer one time before. Plus the dolly I would say is only half the "LBS" of the car trailer. And that would put you at 4500lbs. Three weeks ago I pulled this car almost 600 miles at 75mph couldn’t even tell it was back there. Just had to use a little more peddle to stop.
Originally Posted by Zaairman
All the 150s come prewired with 4 pin wiring...
If anyone has the part number for the later year bracket with both the 7 and 4 pin connector I would appreciate it. I would like to upgrade mine.
Originally Posted by Norm
Some (like my 2001) only had 7 - pin wiring and you needed to use an adapter (which was provided in the tow kit with the relays etc.).
ETA: That $140 is after my discount from my parts guy.
