Trouble code P2106. Plz Help
Old 10-06-2007 | 05:31 PM
jonamond's Avatar
I checked my codes and it says (P2106 THROTTLE ACTUATOR CONTROL SYSTEM - FORCED LIMITED POWER)
I dont know whats wrong. i think i might have done something when i cleaned my throttle body.
Any info on this is greatly appreciated
Thanks!
2005 f150 5.4
Old 10-06-2007 | 11:28 PM
Bluegrass's Avatar
Your truck has electronic throttle control.
If you took the drive assembly apart, you got something messed up.
Why are we cleaning this on such a new truck without a a DTC code as a reason to do so?
Old 10-07-2007 | 07:51 AM
Tumba's Avatar
I think he was advised to do so
Old 10-07-2007 | 11:25 AM
jonamond's Avatar
Truck started stalling from all the build up in there. not great air flow
Old 10-07-2007 | 11:40 PM
Quintin's Avatar
P2106 is an informational DTC. It's set when the PCM sees something is wrong; it doesn't know what to do, so it defaults to a known good operating pattern (in this case, forced idle/no power so it doesn't stick wide open, sending you careening into trees, other cars, or off a cliff) until it's fixed.
You'll very rarely, if ever, see P2106 alone, there's should be another DTC in there - usually something like P2110, 2111, 2101, and a few others that'll get you a better idea of what went wrong to cause the PCM to go into reduced power mode. If you're using a built in scan tool that comes with a tuner, you may not be able to retrieve all DTCs.
Quick Reply: Trouble code P2106. Plz Help
