I Fubarred Help
Old 10-07-2007 | 08:35 PM
newton123's Avatar
I Fubarred Help
Slave Cylinder Was Leaking And I Put Off Fixing It And Just Kept Adding Fluid Until Finally The Pin Came Out Of Shift Tower. At That Point I Pulled Tranny And Fixed Clutch Problem And The Shift Tower. When I Put Tranny Back In And What I Thought Was All Back Together I Now Have Check Engine Light On And My 4x4 Light Is On. Truck Drives Fine And Is Not In 4hi. I Ran Diagnostics On It And Came Up With P0443. Anyone Have Any Suggestions ?
Old 10-07-2007 | 08:51 PM
torkum's Avatar
Check the wiring connector going to the Evap purge valve to make sure you did not disconnect it. Back in the gas tank area.
Quick Reply: I Fubarred Help
