#2 Misfire Confusion!
Alright I know there's been a 100 different posts on misfiring but after changing the plug, COP, fuel injector, and the fuel filter it still misfires. The only other thing I could think of is replace the o2 sensor but before I waste more money and patience, I would like some input from everyone. Is there anything I'm not thinking of or should I just bring it in??
Swap one with two - chances are purdy good that you have a faulty "new" COP. Happens all the time.. Don't attack the O2's - their not the problem.
Check the wiring harness and make sure it's moved away form the AC accumulator.
Also check for rubbing on the harness - bare wires that ground out..
Thats what happening to me and was told to change all 8 cop's plus plugs,I did that and truck still misses at 45mph in overdrive.
I no what you mean about losing patience I been there.
I would like to no what kind of shop I can bring it to (not a regular mechanic)like a diagnostic garage or something.
I wonder if ford would check it out and tell me what it is for a fee.
JOE
Yea , that's what I would try first - But I have also relocated my harness as far away from the AC accumulator as possible - That thing can make your COP system go wacky.
What happens is when people replace there COPs for the first time , they nudge there harness a little closer to the accumulator accidentally.
That will cause misfires all over again - even w/new coils..
Good Luck
Good Luck
