Ring Job - 1999 F150 5.4L
Originally Posted by skynet12
I'm not certain yet that it needs rings. The engine is using about 1.5 quarts between oil changes, but is not leaking or smoking. I just assumed it must the rings.
Originally Posted by biff150
My 97 F150 5.4L uses about a quart between changes. I change it every 3000 miles with Mobil 1. It has used the quart since I switched to synthetic at about 30K. It now has 230K. What type of oil are you using?
