Check Engine Light
Originally Posted by MXrob26
Code: P0174
Lean or rich a/f ratio on eng. bank 2
So I blew the maf with some canned air, and the CEL is still on. What could it be?
What's that suppose to do ?
You have to clean it first
What truck and motor are you talking about ? It says 2004 , but that's not in the picture ...
Its a 2004...Heritage Edition... and its a 4.2 v6
Ok , yea, MAF cleaner or electronic cleaner will work THEN that canned air helps after that.
Make sure you disconnect the battery for atleast 15 minutes.
Look for a leak from your PVC line - I would pull the line , everything and check it all for leaks..
Buy a Haynes or Chiltons manual for your model at your local auto parts..
Originally Posted by projectSHO89
Leave the MAF alone, it won't cause a single bank lean code.
You likely have a vacuum leak as already advised.
Steve
Steve
I didn't think that was correct. I just read through three pages of Diags from Ford and he's right. Here's the key statment from the determination sheets -
"If one bank is negative but the other is not then the MAF is not the cause"
Damn Steve , you know your chit!!
