Turbo charger
Old 02-13-2008 | 12:37 AM
F150 46's Avatar
Turbo charger
I was thinking about turbo charging my 2001 4.2 F150 but i dont know if they make any kits for the 4.2? and if it would be worth getting one for my 4.2. i would appreciate any info you guys have on where i can get one.
Old 02-13-2008 | 02:55 AM
97XL's Avatar
I am thinking on this as well, from what I have researched the hardest part is fabbing up the piping. I haven't found a kit specifically made for the 4.2 but if you can find someone to fab up the pipping for you you'll save some $$$.
You can try googling Turbonetics, they seem to be a popular choice for a lot of truck ppl.
Old 02-13-2008 | 10:23 AM
david@bonesenterprises's Avatar
Former Sponsor
Well just to put my 2 cents in. When you turbo charge your trucks there is a lot of other things that have to happen.
You will need it tuned for more fuel and the correct air fuel ratio.
You will need to get a adjustable fuel pressure regulator
depending on boost pressures you plan on running bigger fuel pump and injestors.
Actually the easy part is the manifolds and the intercooler piping
I suggest take it to a good dyno guy. It will cost a bit, but knowing that your new found power plant is going to be stable is very comforting.
Old 02-13-2008 | 06:58 PM
JMC's Avatar
JMC
Post your questions in the superchargers/turbo section.
JMC
Quick Reply: Turbo charger
