Cam phaser's
Thanks Neal
I know how to degree my cams in my dragbike and understand advancing/retarding cams to move the torque where you want it. At least on my bike I have an intake cam and a exhaust cam so it's easy.
But it doesn't make sence on a single cam that operates both the intake and exhaust valve's plus on an engine that doesn't go over 6K
Heck you want to either increase or decrease the lobe center's timing, but when they are on the same shaft thats alittle harder to do.
Plus when you retard the intake that exhaust value will be getting alot closer to the piston or vise vs.
Just trying to learn why Ford has them
HI!... Well the MUSTANG guys have been deleting the VCT for a few years now. They are not seeing any side effects to deleting it at all. At 1ST they lose about 2-3 MPG but get it back once they get dyno tuned for the VCT delete. I'm building a 5.4 3- valve set-up for my F-150 and the VCT will be getting deleted 1ST thing. Most guys pick up H.P when the VCT is gone. Plus you don't have to deal with all the problems Ford's crappy cam phasers give you. Noise, failure........
Originally Posted by Neal
HI!... Only the 3- VALVE 5.4's and 4.6's have cam phasers.
Originally Posted by ryan42680
I thought only the 5.4 had cam pahsers as it is the only 3 valve motor available right now, the 3 valve 4.6 won't be available till the '09's debut, the 4.6 2 valve will ve the base model motor, the 3 valve 4.6 will be mid grade, and the 5.4 3 valve will be the top motor until the 6.2 comes out. At least that's what I had read through the 09 forum via press releases.
HI!... The 4.6 3-valve has been out for years now in the MUSTANG
hey neil
Hey neil , i think you have just gave me a releaf of so much stress .. can you geyt a hold of me rather its by e-mail or on here . my email is ..sniperoneeight7@aol.com .. ive been looking for a cam phaser lock out . ive been having so much promlums with my 5.4 3 valve motor it isent funnie and it all caused be the dealer ship i took it too . im in the middle of a suit agenst them for messing my motor up but it still dont help the fact the truck isent running right . i would so greatly need your help in any why you can thank you so much
signed
jamie B
need help same problem,are these lockouts something i installed on the oem phaser?
