Royal Purple oil change
Old 04-29-2008 | 10:56 AM
Labnerd's Avatar
Waterman308, the moly used in RP is not the same as the moly used in grease. Grease moly is Moly Disulphide and is black in color. The moly used in RP is Moly Trialkyldithocarbamate which is a clear liquid. Don't attempt to read anything into any advertized dyno tests regardless of product. Dynos can be massaged to get the results you want and are not necessarily true. Even making zero changes to an engine I can get a 5% differential. FWIW, the blends such as the Motorcraft will turn in lower wear metals. If you like moly, Havoline, just plain ol' Havoline, has almost twice the moly of RP and Redline has over ten times the moly. Unless you have oil analysis to back personal claims, usually RP gives nothing remarkable in results. The wear metals are average and life is average. Good oil, just not worth the price for the value received.
Old 05-01-2008 | 11:40 AM
Originally Posted by wreedKR
Just dumped 7 quarts of fresh 5w-20 Royal Purple in my 5.4
I thought these trucks took 6 quarts...
Old 05-01-2008 | 01:23 PM
risupercrewman's Avatar
5.4 3v engines take exactly 7 Qts! 4.6 takes 6 Qts!............
Old 05-01-2008 | 03:42 PM
frankiemcnoosie's Avatar
I use RP in my 10 speed and no snakes have chased me since!!
Good Chit!
Old 06-14-2008 | 07:10 PM
tlfwatch's Avatar
Talking Mabey You Forgot To Put Drain Plug Back In
Just dumped 7 quarts of fresh 5w-20 Royal Purple in my 5.4 and i have noticed you can barely see the oil on the dip stick? when i wipe it off with a paper tell i can tell oil is there but it is hard to see.
is this normal?
Mabey you forgot to restall drain plug
Old 06-15-2008 | 12:15 AM
bt1288's Avatar
Originally Posted by longjohnsilver
On my 98 5.4, 5W30 is recommended. When did Ford switch to 5W20?
My 98 F-150 and my 99 Mustang GT call for 5w30. As mentioned, they did switch to 5w20 around 01 for better mileage.
I use 5w20 in the winter and 5w30 in the summer.
Old 06-16-2008 | 10:21 AM
Norm's Avatar
Why? They are both 5 at cold temp.
If you are concerned with cold starts go to 0w30.
Old 06-17-2008 | 08:25 PM
my05f150screw's Avatar
Originally Posted by buckdropper
I have been using plain old 5W20 since i bought the truck in late 96, I have never had to wrench on the motor EVER. It runs smooth does not burn oil between changes (5000 mile changes). It has way over 250,000 miles on it. Do the math a 20 dollar oil change or a 75 dollar oil change. Royal Purple my azz, Motorcraft 5W20, and a FL820S Motorcraft filter.
DITTO, BIG TIME!!! The motorcraft is so affordable and readily available at any walmart! I wouldn't use anything else! Especially with the dang gas prices getting so high, why spend extra money? The service intervals are still 5k which is way past the ol' 3k rule of thumb.
Old 06-17-2008 | 09:49 PM
Since switching to Motorcraft 5w-20, my truck runs awesome, & it's quite affordable! I'm sticking to the Motorcraft Syn-Blend!.........
Old 06-18-2008 | 12:32 PM
openclasspro#11's Avatar
Originally Posted by alsupercab
I wouldnt use RP in my street car, but when we were driving race cars thats all we ever ran. It was .2 seconds quicker on RP
.2 seconds can be due to alot of things,not just rp oil
Quick Reply: Royal Purple oil change
