minimum CFM for E-fans
Old 05-22-2008 | 05:11 PM
JMC's Avatar
JMC
Sorry, should have added Intercooler piping.
Regards
Jean Marc Chartier
Old 05-22-2008 | 05:48 PM
lenore's Avatar
Smile
Originally Posted by malexander52
That looks really sharp! Which controller did you get, FK35,50,60, etc....?
Did the Lincoln fan come with the shroud? Again that looks really good.
I used the FK35 controller, I talked to Brian at DC controls and he said it would be quite adequate for that fan... I just towed in 105 degree temp with a 6000lb trailer and it did a great job. Water temp never went over 195degrees and tranny temp never higher than 190 degrees. So far everything is great, the wiring is very complete with the controller and of very good quality....no undersize or cheap connectors.
Look closely at my pictures, I made some very simple brackets to attach the square shroud to my truck. none through the radiator... all external to the fins...
Old 05-23-2008 | 07:30 AM
mitch150's Avatar
Regards
Jean Marc Chartier
Thanks JMC, wasn't sure what u were takln' about at first. Your name reminds me of my cousin Jean Luc in France.
Old 05-23-2008 | 10:20 AM
malexander52's Avatar
Cool Thank you Thank you!
Good work my friend! I will be laying down a flag stone patio this weekend so next weekend its off to the parts yard for me! I can't wait. I will go with the FK35. Nice work on that fan man, sharp thinking on the brackets. The last thing I want to do I put ANYTHING through my radiator fins.....
Old 05-24-2008 | 12:41 AM
primerib's Avatar
Nice work on the efan. I have a Mark VIII efan as well on my 02 F150 that I modified to fit my shroud....very simular to the mad enterprises fan.
Old 05-25-2008 | 01:33 PM
electricfrank's Avatar
Mark VIII fans w/ dc controller
or use this Lincoln fan (Mark VIII or thunderbird) seimens 18 inch fans, it moves 4300 cfm and can be found in any u pull it junk yard for $29... Then add this controller which has all of the wiring and hookups...:
http://www.dccontrol.com/0820.htm
total cost $167
Look at my efans under my photos....
I too went with a mark viii fan from the boneyard,50.00$ and the delta current control fk35 controller 125.00$,A very smooth set-up and very easy to wire!And i also like the it makes that cool whining noise when the fan is winding down after you turn the truck off!
Old 05-25-2008 | 02:31 PM
Blown F-150's Avatar
no Mark fans here locally, I will have to expand my search to the oakanagan valley, I remember seeing a few scrap yards on the way out to Kelowna.
I think this is a great idea and I'm going to try and move forward on it as soon as I find a fan.
Thanks alot for the help, yet another example of how this site has helped me out
Old 05-25-2008 | 03:08 PM
Smile mark viii fans
E-bay always has them,just type in lincoln mark viii fan and you'll find them.
Old 05-25-2008 | 06:18 PM
primerib's Avatar
Buy the time you add shipping it could cost you about $100...although they are worth it I would opt to be patient and one will pop up eventually at a pick n' pull for a lot less.
Old 05-25-2008 | 08:05 PM
Faster150's Avatar
the going figure which varies with the radiator and other variables but the rule of thumb is 100CFM for ever 10HP so 2500CFM fan will cool 250 HP.
Old 05-25-2008 | 08:21 PM
I hope to have close to double that when I'm finally done. (I know, I know I'll never be done) But I'm pretty sure I'll never do anything that would put me over 500hp.
I'm going out to a buddy's in Kelowna to do my exhaust, he is gong to check around there and see if something's around there.
Old 05-25-2008 | 11:28 PM
primerib's Avatar
I heard that too....the taurus fan I had prior did a really good job even in high temp, stop n go situations. It worked hard but kept things at a level 205 degrees.
Old 05-26-2008 | 11:43 AM
lenore's Avatar
Also look at late model Ford Thunderbirds with the V8 engine. It has the seimens 18 inch fan also (mark VIII)
Quick Reply: minimum CFM for E-fans
