need help jbrew
need help jbrew
s.e.s light came on today, read codes and 3 came up.po325 knock sensor circut 1 bank 1 po401 egr flow insufficient and po704 clutch pedal position switch malfunction. I think the 401 is the dpfe sensor, right? the other ones i'm not sure of. My truck is a 2000 f 150 4.6 5 speed any help would be greatly appreciated .
PO401 is easy enough - Tons of info on that as you prolly know.
A strange set of codes for me - It's better that someone else handles this one. I do know what the codes mean basically. What I don't know is the relation one might have with the other.
Not confident I could help much here, (that trans didn't make into to many trucks, just the work duty line I thought) so I'll listen to what others come up with for you.
Good Luck
