Ebay Coil packs- which ones are worth it?
Old 09-13-2008 | 10:04 PM
jbrew's Avatar
Originally Posted by UCF-150
ha ha ha, yea Jim, DUH!
You like that one did yuh?
Well the diagnosis is thus far:
I have swapped the COP from CYL 3 to CYL 1. I still get the miss @ ~1100 - 1600 RPM in OD under light acceleration / load. I have not been able to get the CEL to throw a code yet. I did the same procedure to get it to throw the code the first time- basically, from about 40 punch it to about 60 slowed down to flip a u'ey and then floor it back to 60. Thats the only way it'll actually throw the code, otherwise under normal driving conditions, as I said above under light accel in OD, it studders like no other and doesn't throw the code. I'm thinking about getting 1 COP and 1 injector when I get my new plugs. This way, when I swap out the new plugs, I can replace the "thought to be faulty" COP (now on cyl 1) and take it for a spin. If that doesn't cure it, I'm gonna replace the injector on CYL 3. - If replacing the COP fixes it, I'll return the injector.
Sound like a plan?
I can tell you've put some time into this - I remember going thru the same sh^t. Your on the right track and it sounds like you have good plan in mind. I think with the 3 valve, I would head for the plugs first. It could very well be that Coil you have in #1 now, but w/low grade misfires and no cell, it's a PITA.
For a quick fix , you can take your chances and purchase a new coil from the Zone and replace #1 - You might get lucky - but they are about $50 apiece local.
Old 09-15-2008 | 08:12 AM
UCF-150's Avatar
When I was at advanced auto parts, they only carried borg werner COP's which had to be ordered in. Anyone know how well they work?
Theres also a Napa in town and a zone, all of which are about the same distance from my house, so I might stop in there. Anyone know which brands they carry and how good they are?
Old 09-17-2008 | 02:52 PM
UCF-150's Avatar
Just talked to the local napa. As far as plugs go - they don't carry the motorcraft replacements - they only carry the autolites ht1's and ht15's (10.99ea) and the champion 7989's (19.99ea).
HT1's being the direct replacement for the PZT-1F which are currently in my motor
and TH15's being the replacement for the PZT-14F or PZT-2F (not sure which one) which is what I believe Ford now puts in the motors
I would like to go with just stock replacements for what ford now puts in the motor, but have heard that a lot of complaints about the autolites and am worried about using them to swap out.
Also, I told him about my misfire and he told me how common it was and that there was a guy in town that I can bring my truck to and that he can test the COP's and let me know if they're good/bad/weak so that I'm not throwing parts at my truck.
So what do you guys think about the autolites?
Old 09-17-2008 | 04:13 PM
Put the Champions in. Those are one piece plugs. You can also find them for a lot less than 20 bucks, they are $12.87 at Rockauto.com.
If you are going to change the plugs yourself, make SURE you know what you are getting into.
If you want the Motorcrafts, the SP421's (PZT2F) are $8.58 at Rock.
Old 10-07-2008 | 09:54 AM
Hause's Avatar
Update?
Did you ever get this problem figured out? I know you had trouble with the broken plugs, I read that thread. Did the plug change fix the missfire problem?
Quick Reply: Ebay Coil packs- which ones are worth it?
