Scott's Efan build, complete write up
#47
yes sir actually. I was rollin in our 69 camaro the other night and one pulled up next to us. Theres actually two brand new skyline's in Lubbock. They're crazy. I tried to run one but he wouldnt If its one of your buddies tell him to holler at me sometime. i try and get out and go to the car events but its really hard because I'm very active in my fraternity. It's pretty much my life right now.
#49
#50
Good post, good photos and very good job.
Thanks for sharing your truck!
#52
Other points worth mentioning the MPG has made a strong 1.75 MPG jump, this tank has averaged 18mpg 50% city 50% hwy.
The truck is much quieter at freeway speeds, cant hear that fan dragging air anymore.
Acceleration has improved as has passing power and low end torque.
#53
really?? sweet... hell I'd even make the drive down there. Actually some guys from another forum are having a meet in Chatam in Oct. Thats a very cool offer.
#54
#55
We actually shimmed the bracket between that top bolt and the radiator with 2 washers, so roughly 1/4" away.
Im not sure the exact thickness of the bar but i believe its 3/4" wide, if that helps to get things on a better scale in your mind
I saw solid 1-1.5 mpg gain with mine, im honestly suprised scott's jumped up that much. With that much gain it shouldnt take long to make your money back
#57
Mine i used nuts that have a thick washer base clamped around the bottom of it to get the 1/4" clearance... Even once the brackets go through some heat cycles there is still pleanty of clearance between them and the radiator.
And btw the pictures were taken while we were still mocking it up so didnt have final clearance in the pictures, notice that the fans arent wired in at all?
#58
#59
yah thats pretty much how we did Scotts, i was working on the wiring the whole time and starting him on the easier tasks, we worked together on the brackets because alot of the bracket fabrication needs 3 or 4 hands to get it all lined up.....
Also you will need to figure out where you want to mount the switches. If you want to copy the other guys or if you want to copy me
