CEL will NOT go away! help!!!!!!
Quintin chewed on yuh because you told someone to get the code? I dunno ? Bad mood maybe ? He might have something against Mercedes, hard to say man. I missed that one tho.. Darnet!!
yah it was pretty funny, then i came in with the Diagnosis b.c i can read and comprehend the story, right Mtech?
J, here's the thread https://www.f150online.com/forums/en...l-ouchhhh.html
I still stick by my answer ! check your frickin code !!
wow I've missed out alot...lol, so you are saying i can just unhook that hose and code should go away? that is though if the wires are not cracked correct? cause if i'm not getting the proper voltage its still going to throw that code will it not? Thanks alot for the help guys
Also check the connector, there easily damged if old. Some things to do and to check.
