CEL will NOT go away! help!!!!!!
#31
#32
J-Brew:
Thanks for your posting of the EVAP system. I was having a PO455 error, and didn't have enough data to service my system. I have a 98 Expedition. I came across your post using the "search" utility.
Additionally would some body be able to post any other available error messages other than the OBD-2 codes. The air bags, and suspension systems seem to have their own proprietary codes, and are not not found on the site (I think)
#33
Here is a for someone actually using "search" !!
As for the "other codes" this is all i can help with.
Air Bag Fault Code Table
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
I don't know anything about suspension codes ??? Maybe Brew or Pat ??
#34
Lol - I'm out in the shop right now looking at that system on the bench - Fuel tank is - out everthing .. Just waiting for it to warm up in here . It's a b^tch typing on this phone
As soon as I can fire up the computer, I'll give yuh a hand..
It's better if I show you what to check ..
#35
figured I'd rub it in.
#36
Yea, I'm looking for stuff to burn right now - It's freaking freezing here and I'm running low on Kerosene - I better go get some more of that I guess..Good reason to pick up some of these while I'm out
#37
#39
