1997 F-150 replaced timing cover now i don't have oil pressure
Old 10-10-2008 | 11:28 AM
jags52982's Avatar
I have a 1997 F-150 4.2L V-6 It was leaking water between the timing cover and the engine block so i proceeded to replace the gasket. The cover was gaulded on the studs long story short I got a new cover replaced the gasket put everything back together. I started the truck as I was inspecting for leaks I heard a tapping sound I have no oil pressure what did I do wrong I can't figure it out.
Is it possible that the gasket is blocking a porthole for the oil?
Old 10-10-2008 | 02:13 PM
Matts ford's Avatar
the 97 and some 98 4.2 v6's had issues if you didnt service them on time. you may need to drop the oil pan and clean up the pickup tube screen or replace the whole pump and the screen.
Old 10-10-2008 | 02:16 PM
jags52982's Avatar
Maybe I'll try that I was thinking of taking the timing cover back off it just seems weird that it was working fine before but now it isn't, like maybe i did something wrong.
Old 10-10-2008 | 02:25 PM
While you have it apart, you should change the upper and lower intake gaskets too - they were a known issue on the 97 and early 98 4.2's. When they leak, they leak into the cylinders and can cause a hydrolock.
Old 10-10-2008 | 03:03 PM
jags52982's Avatar
ok so there wouldn't be anything i did with the timing cover that would affect oil pressure
Old 10-10-2008 | 03:39 PM
jags52982's Avatar
I was reading up on trying to remove the oil pan is it true you have to remove the engine to take it off
Old 10-10-2008 | 04:23 PM
minimonster17's Avatar
no, but on a 4x4, you have to drop the front differential, unbolt the engine mounts, and jack up the engine to gain the clearance to drop the oil pan.
Old 10-10-2008 | 05:59 PM
jags52982's Avatar
ok i think I will remove the oil pan and inspect the pick up screen
Old 10-10-2008 | 06:02 PM
MITCHYKINS's Avatar
isn't the oil pump on a 4.2l in the timing cover
Old 10-10-2008 | 06:09 PM
jags52982's Avatar
Yes but I think there is a pick up tube with a screen in the oil pan Am I correct?
Old 10-10-2008 | 06:12 PM
jags52982's Avatar
I just am frustrated at this point the truck was working fine just had a pretty good water leak between the timing cover and the block I changed the timing cover gasket and now I don't have oil pressure It doesnt make sense to me.
Old 10-11-2008 | 12:30 AM
pos racing's Avatar
silly question,did you drain the oil pan after repair as coolant will run into pan when cover removed?
Old 10-11-2008 | 11:20 AM
jags52982's Avatar
Not a silly question but yes I did drain the oil pan
Old 10-11-2008 | 10:11 PM
have you dropped the pan yet to take a look? that would be the next logical step... it's really not as bad as you're thinking...
Old 10-13-2008 | 08:51 AM
jags52982's Avatar
no I havent that will be my next step hope you are right about it not being too bad
Quick Reply: 1997 F-150 replaced timing cover now i don't have oil pressure
