autometer oil pressure
Old 10-26-2008 | 02:01 PM
dolfan2751's Avatar
I just installed an autometer oil pressure sender 4327(electric) with a tee. (2006 fx4)The factory sender works but the autometer does not? I checked the hot and ground and the light works. Any ideas? thanks
Old 10-26-2008 | 02:22 PM
built54's Avatar
did you wire it correctly?
Old 10-26-2008 | 02:41 PM
dolfan2751's Avatar
Yes sir. A sender wire, hot wire, ground wire and a luminous wire
Old 10-26-2008 | 04:03 PM
dolfan2751's Avatar
Works now. We took the senders and tee back off cleand up and reinstalled. Cleaned up tools and started the truck amd BAM 75PSI.The only thing we can figure is some trash or the autometer sender was stuck???
Old 11-14-2008 | 01:32 PM
badassfx4's Avatar
I just put in autometer cobalt oil psi and trans temp in my 2008 fx4 what are you running for oil psi, mine is around 80 at start then drops to 35/40 normal driving and around 20 idle. Cant tell if thats normal or the gauge is bad.
Quick Reply: autometer oil pressure
