Engine Swap Help
Old 11-09-2008 | 10:37 AM
pu2ded0's Avatar
Engine Swap Help
Looks like my '97 5.4 has some internal issues. It smokes more as it warms up and the smoke now has a blue tint to it. Still misses, running on 7. Can someone tell me what year model engines would be an easy swap? Also, what year mileage engines are low maintenace (spark plug problems)? Gonna try to buy a whole vehicle and swap it out.
Old 11-09-2008 | 11:30 AM
Matts ford's Avatar
the late 03 5.4 has more threads in the heads so the plugs dont blow out. but any 97-03 5.4 or 4.6 will bolt right in but keep a 5.4 so you dont have to change the tunes in the computer. just look for an expedition or f150 5.4 within those years.
Old 11-09-2008 | 12:44 PM
pu2ded0's Avatar
I wanna stay away from the ones that blow plugs out. I had a "97 and "01 5.4 truck before. Never any problems with these. Gonna try and buy a later model from salvage aution, jus wanna be sure i don't get the one with the sparkplug issues.
Old 11-09-2008 | 12:49 PM
jbrew's Avatar
Then buy something other than a Ford or time sert it. I wouldn't let the blow out determine the year in that engine. Both 5.4L and 4.6L /97 -03 use the same chamber threads. They changed late 03.
Old 11-09-2008 | 12:52 PM
pu2ded0's Avatar
with my luck, nothing is over dramatized. the truck i have ran perfectly until i finally decided to restore it for my son. now, got it ready for the road and the engine is smoking badly. jus kinda don't know what to do. gonna drive it 'til it either craps out or i find replacement.
Old 11-09-2008 | 12:58 PM
jbrew's Avatar
Head over here for your motor. See what's available in your area, just type in your zip -
http://car-part.com/
Old 11-09-2008 | 11:02 PM
tjk_in_cny's Avatar
Very nice site Brew, saved it to my favorites folder (auto repair).
Old 11-10-2008 | 01:25 AM
jbrew's Avatar
Yea, it's a pretty cool way to find a motor or trans close to home. Great database locator.
Old 11-10-2008 | 08:02 PM
pu2ded0's Avatar
thanks
Great site, just wish i could get around swapping the engine. gonna tune it up and hope for the best. maybe fuel burning since it isn't firing on all 8.
Old 11-10-2008 | 08:47 PM
jbrew's Avatar
Get it firing on all 8 if you can. I would compression test something like that. Misfiring shouldn't result in smoking. Rings and valves most likely.
Make sure the PCV system is clear. Motorcraft valves work the best in these things.
Old 11-12-2008 | 02:44 AM
AlfredB18's Avatar
Get a compression check done.
That engine may have lived the good life already. You see that happening right before your eyes.
Old 11-14-2008 | 01:46 AM
dalesdeadbug07's Avatar
I was wondering since would the lighting engines work in his truck or did those change. is the computer the same and the wiring harness
Quick Reply: Engine Swap Help
