f150 rattling noise
Old 11-09-2008 | 10:49 PM
solrac6262's Avatar
f150 rattling noise
hello guys, here is the thing, when driving and at idle., the engine runs okay......
When I tap the gas, or when I am like uphill or something and I put load on the engine and i tap gas to accelerate
sounds like ***** rattling in a spray paint can, I hear a lot of people saying that it could be the gas, even switching to a higher octane gas the truck still does the samething, I dont remember hearing that noise when new, but I had other cars that did the same noise..
has anyone else had this strange sound btw
f150 07 king ranch
Old 11-10-2008 | 01:27 AM
It still does it on the highest octane gas you can buy?
Old 11-10-2008 | 01:35 AM
solrac6262's Avatar
I was using regular, then switch to mid, but I think I only fill the tank like two times with the mid... and samething.. or do I have to stay on the mid for a longer time?
Old 11-10-2008 | 03:41 AM
If it's doing it on mid, try super premium. If it stops, then you know it's spark knock and you should keep using it till you can get it fixed, as spark knock can cause engine damage if it continues. Discuss this with your dealer while you are still on warranty.
Old 11-10-2008 | 04:04 AM
EddiesF150's Avatar
Yeah, it definately sounds like detonation... What engine is it and what mods have you done to it?
Old 11-10-2008 | 07:33 PM
solrac6262's Avatar
thanks Glc, as soon as I get empty tank Ill do the premium, does the truck normally improves on the first fill up on premium or do I have to wait for a couple of gas tanks.
Old 11-10-2008 | 07:35 PM
solrac6262's Avatar
5.4 the mods, only switching from the pirelli tires to bridgestone duellers LoL
Old 11-10-2008 | 07:37 PM
You should notice it within 5 minutes if you wait till the light comes on, then fill the tank.
Old 11-10-2008 | 09:21 PM
solrac6262's Avatar
ok I will let you know if the problem is gone... if not is this a serious problem?normally the stealer says that they can't duplicate the noise LoL
Old 11-11-2008 | 02:59 PM
If super premium shuts it up, run that tank down to the light and go get the cheapest 87 in town. Get it warmed up, verify that it pings, and ask the dealer to let a tech ride with you, go out with him and make it ping.
Old 11-11-2008 | 03:26 PM
Mark 2000 Ford's Avatar
Rattling sound
My Ford truck rattled also...same symptons. I replaced my catalyic converters on my 2000 Ford F-150 5.4 Triton, and all is quiet!! I wish I had done it earlier. My truck had 150,000 miles when I did this, earlier this summer.
Old 11-11-2008 | 04:17 PM
If it's the converters, high octane gas will not shut it up.
Old 11-11-2008 | 10:41 PM
solrac6262's Avatar
thanks all.. i will change gas grade to premium I put some additive a fuel cleaner . I think it doesnt sound alot.. I can barely hear the ping but sometimes it pings but it doesnt do it all the time..
Old 11-11-2008 | 11:29 PM
If it does go away with premium, it may need a good intake system cleaning, especially if you have been using offbrand gas. I'd still discuss it as a warranty issue with your dealer.
Old 11-11-2008 | 11:38 PM
solrac6262's Avatar
hey man I only used shell gas
Quick Reply: f150 rattling noise
