Ticking noise! (could it be loose plug?)
Hey guys, After reading too many pages on the 2v plug issues I went out and started my early 03 screw. I noticed a little ticking noise, and this past week had noticed alittle rougher idle. I can't work on it tonight but will tomorrow evening. The truck will only get drove 2 miles maybe, I hope it doesn't spit one out. What will I need tool wise to check the torque on the plugs, I've read about a longer plug socket being needed? Is anything needed to remover the coil packs? Should I replace the plugs anyway (71,000 miles)or just make sure their snug?
Please help
Thanks Guys
BTW I now I'm paranoid but my last truck cost me way too much in the year I had it. I don't want to start this all over again.
Please help
Thanks Guys
I was told don't change them unless you HAVE to- no undue stress on those fragile threads! As for loose- I believe they spit it out from thread failure, not getting loose. I don't remember the exact sizes, but it's a small metric socket to get the coil packs off and a good spark plug socket with a rubber inside to hold the plug, the plugs are down in 4-5 inch deep holes and you need that and an extension to get to them safely. They also loose exhaust manifold studs, they rust off and eventually start to leak. Believe me- spitting a plug was no ticking sound!!
Yeah I'm hoping its just a normal noise, but don't want to just assume it is.
Its pretty faint sounding and only noticable at idle. I didn't notice any difference while reved up or driving, so I'm praying its nothing (injectors or valvetrain noise?).
Would a loose plug rattle at all rpms?
Maybe its only noticeable after reading all the post of horror stories of $2,000 bills and time serts?
Thanks for the replys
Aaron
Aaron
I was thinking they spit out plugs because they become loose over time and then the threads fail??
Ignoring this seems like it could come back and bite me hard?
Aaron, mine cost $9.00 to fix- tap out the hole and install an insert. They sell the kit at auto parts stores. I had over 170,000 miles on it so I figured a few alum shavings wouldn't hurt too much in the cylinder.
The threads in the head are only about 1/2 inch long, they only hit about 3/4 of the plug threads! There is so little meat that they fail.
Had you changed the plugs before one blew out?
How loud was the rattle before the plug blew out?
BTW 9 bucks ain't bad, I thought the time sert kits were like $120.00 and up.
No, I never touched it. It happened with NO WARNING! Just BANG and then it sounded like a demo derby car! Flew out and took the threads and coil pack with it. That was the part that bites, buying a coil pack.
If you do check them, just make sure they're not l o o s e, I wouldn't tighten them.
I wasn't going to crank em all down.
I was under the impression I could just check them to see if thier tight, and torque em back down to the 14ish lbs.
Yea, only tighten them if they're obviously loose- otherwise you disturb the threads. It's the taking them out and retightening them that can damage the already weak threads. There is simply not enough threads - poor design. On top of that they're aluminum. it's a case of don't fix what's not broken. They will not rattle if loose, if they're to the rattle stage- they're gone!
Please help
Thanks Guys
Please help
Thanks Guys
I'll probably just make sure their tight tomorrow adding di-electric grease as I go, and change them out when I have more time.
Would 13lbs of tq be, me twisting the socket and extension NO Ratchet hand tight, Or more like just a little snug with the ratchet?
I might just go buy a tourqe wrench.
