Throttle Body
Old 11-13-2008 | 04:15 PM
toast1850's Avatar
Throttle Body
About two weeks ago I attempted to remove my throttle body to clean it but ran into a problem. I got everything disconnected except for one rubber hose located in the back by the firewall. This hose was secured with a metal clamp. When I removed it fluid started coming out. It looked like engine coolant. I didnt know what to do so I put it back on. Is this normal? I would like to completely remove the throttle body to clean it good. Any suggestions please help. 2005 STX F150 single cab 4.6
Old 11-14-2008 | 12:28 AM
jbrew's Avatar
Cold claimant system that heats the plenum around the IAC so she don't lock up on yuh. Hold hose up and shove a big bolt in to plug while you the plenum and TB.
Quick Reply: Throttle Body
