04' cruse control
Old 11-14-2008 | 05:16 PM
thorn38451's Avatar
04' cruse control
does anyone know how to run a self test on the cruse control on an 04 f-150. or how to reprogram it? it won't come on at all. any ideas?
Old 11-14-2008 | 05:26 PM
kingfish51's Avatar
Check for bad fuses, brake lights out, and a bad brake light switch on the brake pedal.
Old 11-14-2008 | 05:58 PM
Matts ford's Avatar
have you had the cruise control recall done to it? if you did you may need to check the fuse that was installed in the wire.
Old 11-14-2008 | 09:27 PM
kingfish51's Avatar
04's do not have that recall. That was only on prior model years. 04 set up is not the same.
Old 11-14-2008 | 10:38 PM
thorn38451's Avatar
brake lights are on. not sure what to try next.
Quick Reply: 04' cruse control
