Check engine "cylinder 2 missfire"
Old 11-14-2008 | 10:29 PM
baxternick's Avatar
I was sitting at a stop light the other night and my truck (97 4.2L) started to idle funny. The check engine light came on blinking almost right away. I turned the truck off and back on and it ran fine but the light stayed lit solid now. I went to have the code read and they said cylinder 2 missfired. What can cause this? I have replaced the plugs (autolite), coil, and plug wires. Also changed fuel filter, air filter, and the vaccum elbow that goes bad above the intake because it was cracked over the summer. I have been chasing a weird power loss for sometime... Here is the old info on that problem....
https://www.f150online.com/forums/v-...er-2k-rpm.html
But that has been on and off for somtime and almost impossible to trouble shoot. So are these two problems linked, and what causes a missfire on 1 cylinder? Thanks in advance!
Old 11-14-2008 | 11:01 PM
jbrew's Avatar
Originally Posted by baxternick
I was sitting at a stop light the other night and my truck started to idle funny. The check engine light came on blinking almost right away. I turned the truck off and back on and it ran fine but the light stayed lit solid now. I went to have the code read and they said cylinder 2 missfired. What can cause this? I have replaced the plugs (autocraft), coil, and plug wires. Also changed fuel filter, air filter, and the vaccum elbow that goes bad above the intake because it was cracked over the summer. I have been chasing a weird power loss for sometime... Here is the old info on that problem....
Autocraft ? - That's the funniest thing I ever heard. You have some Mutant plugs in there/ Half breed - maybe inbred
As soon as you post what the hell it is your driving / engine etc etc.. You may get some help.
You edited your post - Did you try to pimp me ? Well , glad I quoted your first one
Check your wires, but I bet it's the plugs. - Autolites aren't specced for that motor - That's why the same company who makes Autolite , makes Motorcraft as well. Motorcraft are the spec plug. Autolites aren't the right heat range and don't last long. Thro the correct plugs in there to start.
Quick Reply: Check engine "cylinder 2 missfire"
