Spark plug head removal
I've never pulled the cab off a 2004+ F150, I don't know how involved it is. Expeditions and Navigators are kinda close though, and lifting the body off a Navigator is easy. Most of the wiring harnesses stay with the frame, unbolt the steering shaft, master cylinder, A/C and heater core hoses/fittings, and up, up and away.
wreedKR- Did you (or they) break a plug (or 3) or were you just curious? i can't imagine having to pull an engine OR cab for a broken plug with all the knowledge (and extraction tools) they have now for that.
jethat- to top it off, I think if I broke a plug (or 3) I would be very tempted to put a heavy piece of plywood close over the plug hole and rev her up good. Early on when this broken plug thing started (before Ford even came up with the extraction tool) there were a couple of guys who tried that and it worked (blew the broken piece out), but i haven't even read of anyone trying it since they came out with the tools. If it works it would be a lot quicker (and you don't have to worry about pulling the cab, head or engine!)
