Manifolds or Headers.
Old 12-20-2008 | 09:27 AM
jbrew's Avatar
Originally Posted by JoryWLU
What if I get 4 stainless highflow cats? what do you recommend then, I also already have a 3 inche mandel bent vortext exhaust, and K&N cold air. Was thinking of getting a bbk throtle body, but worried if the throttle body should require other mods.
Stop right there, your set. Don't get the TB. Get some heads or have them worked over, then add more bolt ons to enhance. - You'll need to tune..
You'll need bigger injectors for more fuel. What goes with more fuel ? More air - Now add a bigger TB (NA) - She'll eat it up.
Or just supercharge.
Old 12-20-2008 | 12:49 PM
JMC's Avatar
JMC
Two high flow cats are enough. You don't need four of them.
Old 12-20-2008 | 01:36 PM
shifty_85's Avatar
so the shortys vs longtubes if you have lets say a cold air intake and E-fans wouldnt the numbers be better for longtubes then? you have more air coming in you need a better way to get rid of it....
Hey Jbrew is it really worth 200 and some odd dollars to get that 75MM TB? ive been debating it for a while it "Claims" 10-15 more hp and i would make my Elbow bigger too. or should i just save up another 200 and go get dyno tuned by livernois?
Old 12-20-2008 | 01:46 PM
built54's Avatar
Just to clear some things up. I Had high flow cats with manifolds. Put the shorties on, gained no hp or tq anywhere. put the long tubes on and gained 30hp/35ftlbs. These gains were not with my current engine.
Old 12-20-2008 | 02:01 PM
jbrew's Avatar
No, waste of money.
Old 12-20-2008 | 06:24 PM
JoryWLU's Avatar
Thanks for the adcive, I starting to get I better idea of what I am going to do.
Old 12-20-2008 | 06:31 PM
jbrew's Avatar
Like Mister JMC said - Just two -
Wanna hear it ? Turn it up !! - http://picasaweb.google.com/jbrew393...40433327124514
Old 12-20-2008 | 06:36 PM
phil6608's Avatar
I think that was clear with 99% of us but evidently not with 1%
Phil
Old 12-21-2008 | 05:32 AM
JoryWLU's Avatar
When you say just 2 cats, you mean instead of running four, just run 2 high flow cats. I was getting the inpression that they were recomending putting on two high flow cats and keep two of the stock ones.
Sorry for be an amateur. But I am the first to admit it.
Old 12-21-2008 | 12:35 PM
JMC's Avatar
JMC
I am running only 2 cats. The precats, first ones in line, are gone. I still pass emissions with the remaining factory cats.
Old 12-21-2008 | 01:54 PM
JoryWLU's Avatar
do you get any gains from getting rid of the precats.
Old 12-21-2008 | 04:27 PM
Originally Posted by 4.6 Punisher
After reading that article, I don't want to be the 4.6 long tube guinea pig anymore. They do need to do that test on a 4.6 mustang as well.
why?? the mustang 4.6 has a different power band than the truck 4.6 due to the tune and intake manifold differences
Old 12-21-2008 | 06:04 PM
JMC's Avatar
JMC
I don't know as I didn't dyno before and after. I removed them to fit my headers.
Old 12-22-2008 | 01:43 AM
JoryWLU's Avatar
If I wrap my headers, would that help with corrosion????
Old 12-22-2008 | 03:43 AM
shifty_85's Avatar
do not wrap them you will destroy them faster the heat has no place to go because the wrap is there keeping the heat in and in less then 6 months nothing will be holding your headers togther excpet for the header wrap Jbrew gave me a site that explained it. i just got home high temp header paint workd ok but michigan winters are brutal on stuff with all the salt and snow
Quick Reply: Manifolds or Headers.
