Odd Vibration
Old 12-22-2008 | 10:54 AM
patd59's Avatar
Odd Vibration
First off, I would like to state that I am new to this forum, and I hope this is in the right section.
I have an 06 s.crew w/ a 4.6. I've noticed that when idling between 600-700 rpms, I get this vibration and buzzing sound. Im not 100% sure where it is coming from, but I can sort of feel it coming through the brake pedal when I sit at a red light. I don't actually think its the brakes, though, but that maybe it's something in the lower part of the engine compartment or something. I don't know. I kinda have a hard time explaining it. Has anyone else had this problem??
I think one time someone told me it could be a heat shield of some kind, that makes sense to me. Any suggestions would be aprreciated. Thanks.
Old 12-22-2008 | 11:11 AM
f150fella08's Avatar
well wecome to the site, and yea i had the same problem with mine, a exhaust hanger broke with my true dual flowmasters and when i sat at a red light it would rattle, but now i have straight pipes so that fixed that lol,
you may check underneath the truck for broken hangers or a heat shield that fell down, heat shields always fall off, no big deal just put it back up or take it off
Old 12-22-2008 | 06:34 PM
patd59's Avatar
Thanks for the tips, F150fella. I'm willing to bet more on a heat shield, cause I replaced my exhaust and still have the rattle. Just wanted to confirm my suspicions. I'll check it out tomorrow when I have time. This board is very informative, proud to be called a member here!
Old 12-22-2008 | 07:27 PM
Faster150's Avatar
bad joke comes to mind....
Old 10-01-2010 | 09:27 PM
redragon's Avatar
i have the same problem with my truck my brake pedal and my gas pedal have a vibration in them i can also hear a rattle that sounds like its coming from the intake area that is where the vibrating s coming from. the vib is kinda intermittent doesn't really happen at certain times but more pronounced when the engine is hot also i dont know if their related but my **** intervals are strange it seems like it wants to shift up way too early and takes a considerable amount of pedal accel to get it to downshift if i come to an abrupt stop at a light it rattles and vibrates the pedals and then usually levels out?
Old 10-01-2010 | 09:38 PM
jbrew's Avatar
Idling between 600-700 RPM's is incorrect. Their not programmed to idle that low. So somethings definitely wrong. Should have a DTC.
Old 10-02-2010 | 12:15 AM
jbrew's Avatar
If it's truly idling that low, -have your cats checked for restriction. Or your drive by wire is screwed up, (throttle body).
Quick Reply: Odd Vibration
